Can I get an aero box tutorial? Lol
I have been hearing aero ports are the way to go. I don't have a whole lot of space in my trunk (2001 Malibu) and I want to make a box with aero ports for a 15" XXX. That being said, I have absolutely no experience with aero ports in any way.
What I want to know is...
How do you decide on the placement of the ports?
Should I do sub to trunk lid and port to driver? Or both to trunk lid?
How do I know what size aero I need and length?
Held in place by glue? If so, what type?
Do both ends need flares?
Would there be any way of saving the box pictured since I made the port too small?
I need about 4 cubes and I want to tune it to like 36 Hz.
Max dimensions are like 34"W x 16"H x 20"D
Box plans and any tips on how to make them would be greatly appreciated. I have made normal L ported boxes using Torres so I know how to make them, but thats about the extent of what I have done.
Here is a slot ported suggestion that will be louder than the box you have, aeros are no good option for your dims.
Enclosure Specifications:
Fb = 36.094 Hz
Vb = 4 ft^3
External Height = 16.5 in
External Width = 34 in
External Depth = 20.5 in
Port Width = 4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 16 1/2
Left & Right Sides = 18 1/4 x 15
Top & Bottom = 34 x 18 1/4
L Port Internal Assembly Parts:
Front to Back = 14 1/4 x 15
Extension = 2 1/4 x 15
Let me know any questions.
So here are a couple things I have picked up from others as far as aero porting:
-keep port volume between 8-12 in2 per cube of port area
-end of inside flare must be at least 1 port width away from the side of the box
Typically in a trunk build, most people have the best luck either putting the sub back or seal it off facing forward with port forward. Port size/number/length is chosen based on getting the proper port volume and desired tuning. Flares are used on both ends to get optimal efficiency from them and to avoid port noise/chuffing. Many aero ports come with one of the flares read to be screwed or glued onto the box. I feel a little less retarded today and re-did that box I made before but with real sized aero ports than you can buy at parts-express lol. This is what I came up with
Now would I put all 3 ports next to eachother? And do both ends come flared on ports you buy from the internet? Also is this something you have tried in your malibu? I believe we have close to the same trunks, i have a 2001.
<_< dammit, didn't think of the flare outer diameter. Our trunks should be the same, no i haven't tried it in mine, and yes the ports come with both ends flared from parts-express.com i believe. Search "ports" at PE and you can see them. Might not fit with the flares. Imma just quit now since i fail at aeros evidently lol.
Aeros can be purchased from partsexpress.com BUT this is a 54mm Xmax driver, you NEED more port area.
i use pvc as aeros. flares are like adding the45 to the slot port. u dnt need it, its just better. you buy pvc, heat it up on some round objeccct and push down to make it flare out. its what i did for my box but no flares.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
I built a box for a XXX using a 6" aero port and it did very well. I also built one using a kerfed port with much more port area and it also did well but I'd say the extra port area was not necessary.
I have a Grand Prix with similar room and a SMD 15'' going on a SAZ3500 @ .5 ohms... What do you think?
-and I saw the longer the port, the deeper the bass, can I use a PVC coupler and put on an extension for lower bass for daily driving?
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
  • Who's Online   0 Members, 0 Anonymous, 2132 Guests (See full list)
