i just received my xtx5000.1 and i need to make sure it gets 14.4v's to get the full potential. i know i need an h\o alt and this weekend ill be doing the big 3 in 0\1 but what second bat should i get in order to to achieve this?
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
you know you arent getting 5k out of htat thing right.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Some cars don't charge at 14.4. I start up cold at 14.7 but warmed up I charge at 13.6. With a 270 amp alt and 3 batts.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
yeah i know. i just ordered my 2 ssa icons which match up perfectly for 2500 rms at 1 ohm. so i guess what i'm getting from you guys is that not all vehicles actually put out 14.4v? so should i just get a second bat and call it a day then?
2 xs power d3400s
2 runs of shca
2 18 ssa icons
you should still get a high output alt and second battery, you want to be able to keep your voltage up at all times because 2500W pulls a decent amount of current.
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
i float at around 14.8 and 13.2 car off. if i can get an avbm to work on my truck maybe more when needed
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
for that amount of power would the xs power d3400 be big enough you think? and i have a yellow top but not currently in. i just have for the most part a stock battery under the hood. should i be able to keep that there for awhile or replace both with the same brand?
2 xs power d3400s
2 runs of shca
2 18 ssa icons
  • Who's Online   0 Members, 0 Anonymous, 2887 Guests (See full list)
