2010 Mustang GT Walled; It Was Fun, Time to go Fast
Must build
It stronger
Should probably double up the step up where the back wall connects.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Must build
It stronger
Why? Every single piece of this enclosure is either connected to or butted right up against a part of the car.
SMD Super Seller
My Feedback Thread
too many pieces means too many pieces
every joint is a weak spot
glass helps yeah it just worries me a bit
This must be WAY TOO MANY pieces then. 2000 Mustang doing 152 out of the box, 155 potential.
SMD Super Seller
My Feedback Thread
hope you used some sort of buffer between foam and headliner
R.I.P!
(Nov-29-2009)
92 explorer
current build
Must build
It stronger
Just saying bro, but egh, what do I know about walls :)
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
it is too many pieces. all those little pieces cause so much work and each one harms the integrity of the box
ill just say this. i learned from my fail wall. if any piece of that box moves (or the box as a whole) you have ruined the car
my headliner got jacked severely. probably would have only gotten worse too but i aborted the project pretty fast
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Taped off the areas that will get the most glass. I kinda don't know where to go from here. Can I just lay the mat and resin over the tape?
Also, I see no need to use the expanding foam.
SMD Super Seller
My Feedback Thread
