2010 Mustang GT Walled; It Was Fun, Time to go Fast
Any ideas on bracing the sides yet?
I think 2x4's on the inside, like I did for the port flex on top. I really think the second baffle is key, though. And sealing it up.
Thats what I did except on the outside. Helped mine tremendously.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
How did you calculate your box volume. I did mine in Pro E just now and it's giving me 7.7ft^3 at the smallest I can make it. So yours should be pretty damn big. I initially had mine at 11ft^3. I'd rather be over than under in my box since it is a lot easier to take up space but if you give me sufficient internal dimensions I can draw you up a cad of your box so you can know your exact volume.
I usually do estimates until I get closer to finishing my box and my estimates had me at 6.2ft^3 and that's a difference of basically 2x2 leaving the long one the same. So your volume may be off some as well if you did hand calculations for odd geometry. I would need to know the angles as well if you have them.
I'll get you some exact measurements in a day or two, appreciate it. I just figured it out by sketches and calculator, but I think I was too generous on how much bracing displacement would be.
SMD Super Seller
My Feedback Thread
Still a good number and congrats on the hardware today.
01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable
Team ShokTEAM SUB SONIC ADDICTION
Nice number bro...an only a light clip lol... I clip pretty hard when I burp...there's a limit though were you start losing dbs..an I do same numbers at 2 freqs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Thanks guys, its got plenty left in it.
I did decide though, that I will run this setup the rest of the year, then strip the car and do a dedicated bass vehicle next season. Has nothing to do with the score today, actually decided on it a couple days ago.
SMD Super Seller
My Feedback Thread
Fuck yes. Do one of those huge ass pedo vans lol.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
