2010 Mustang GT Walled; It Was Fun, Time to go Fast
What ohm load are you at on the amp? play with reconing subs to a benificial ohm load rather then add power.
The subs are D1(.7), so my starting ohm load is .7 at the amp.
Have you ever thought about reconing to D2's and wiring to .5 nominal? I've always heard that series connections rise faster than parallel so if that's true that would help some, and the lower nominal load should help a little as well.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Its a fun car, Will, I recommend a small system, keeping the 4runner for stereo fun.
cool, yeah I've been wanting a Mustang for years, I want a 05' GT Pewter Gray 5 Speed V-8, maybe I can get it next year, yah keeping the 4Runner (1 more payment left on it) I'm thinking something crazy w/8's in it like 4-8 of them on like 2-3k in a bandpass in the trunk just to ride around in on weekends
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
Yep, going over some wiring configurations right now actually. I need to know what AA d2 measure on a dmm first though. LIke the d1's measure at .7, the d2's probably measure low as well. Also, i'm a little torn about reconing brand new subs. We'll see.
SMD Super Seller
My Feedback Thread
Pretty sure their D2's read 1.4, but with rise you'd never see that .35 load once it started playing. I'm sure James has more experience wiring that low and could give better input, I'm just thinking outloud. I've never wired below .5 nominal personally.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
Couple hundred for recones is a whole lot cheaper than new amp etc...also try dual inputs should see a few tenths of a gain and as many batts as you can get if you wire down
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I have room for 2 more 6500's and already have the dual inputs. I guess what i'll do is finish up the box and pound these subs to death, then order the d2's. I never considered rise when I ordered, to excited and anxious I guess.
Thanks for the input Ray.
SMD Super Seller
My Feedback Thread
That's retarted every time the subs stop between bass drops the amp will see it'd nominal starting ohm load with or without rise so if he wires to .35 ohms the amp will have problems
Also ken what's this 149 stuff I saw a 152
Problems alpine? I've been running my amps at .35 for years daily...I luckily rise to only 1ohm from .35 and get awesome power...ask AI Ray what he wires too...ken said his voltage hardly moves..which to me says he's not making that much power....just my opinion...
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Yes problems some people get lucky and it takes a long time for those problems to show up but I willbput money on it one day the amps will fail
Also ken you saw that 152 so when you demo windows down that's how loud it is just falls short sealed up
I knew it was louder than a 149 when I got my demo.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
