New build isn't as loud as it should be.
I have the same headunit man and everything is flat so no you do not need to have it blasted. This headunit doesnt seem to get close to full rca output until volume 30 or so. I set mine up with a 0db test tone, the x395 doesnt clip at full volume so go back and reset your gains woth ub level at 0the and volume maxed
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
I have to have the subwoofer level up or there is hardly any power sent to the sub. It feels like a single 8 on 100w(well, you can't really feel that LOL).
As far as the head unit not distorting, I believe you, but my speakers are bad(polk db651's). They have a slight distortion noise to them at certain frequencies at any high volume, so I don't like to go higher than necessary.
Skar VVX12 D4 wired to 2ohms
Soundstream Rubicon 1600w
Kenwood Excelon KDC-X395
When I go to set my gain with a 50hz tone playing, I see very low voltage even when the gain is up higher than it should be. Gain up almost all the way and I'm not even seeing 500w. Subsonic is set to about 25, lpf at about 80. No bass boost. Battery voltage lowest drop I've seen is 14.0. Subwoofer lvl on the headunit is at max as it should be. Volume set to ~27 out of 35 max. Knu 4ga power and ground.
The input voltage selector is at 2-8v instead of .1-2v because of my 4v preouts. I'm assuming this is how it should be.
Help me out, guys!
I had to put the input selector on some planet audio bb2400.1s on the .1 to 2v setting even tho i have 4v preouts as well to get the right output from them. It was like 3 to 4 times as loud like that for some reason.
2000 zx2: Rebuild with 8 12s on a 10k underway!!
MY BUILD LOG
Instead of you guys just guessing about the voltage pre out and subs turned all the way up just call and ask kenwood. That way you know for sure. Then go about setting your gains.
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
or stick that meter on it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
an old alpine I had used to have had a setting similar to what I think you are describing. You had to turn "subs on" to get a high voltage to the sub out rcas on the back and the sub level couldnt be adjusted until that was turned on. The problem was something was reversed so when I turned "subs on" it actually sent low voltage to the rcas and the sub level control had to be turned up high to get output and then of course sounded like poo. So instead i ran it on "subs off" and controlled output through the amp remote.
Seems like a similar problem here, I would call Kenwood and see what they say or if it isnt a huge hastle try a different head unit if you have one laying around.
Team NorthWestSPL
Im not sure how many of you have actually scoped a gain or anything before but almost all head units don't put out max output voltage unless they are turned up all the way on the sub out.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Interesting, the shop set my gain but on my X592 I never take it past 28/35 when playing CDs and never above 30 when using my iPOD thru the AUX. Sub level is always at 0 and its gets plenty loud.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Sub vol all the way up
Deck on 30
Eq flat
Input sens set to the lower voltage setting .2
Play a constant bass song like jeezy or something.
Slowly turn up gain until it stops getting louder.
Thats all you need to do.
  • Who's Online   0 Members, 0 Anonymous, 1047 Guests (See full list)
