? about subs
sealed boxes giving "deeper" base is a myth.. and what amp do you plan to run them off of?
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
:popcorn:
Lol...can I haz sum??
What kind of car are you puting them in? You probably be happier with a ported box unless you don't have the room for the extra space. And yea what kind of amp?
Edited by sprkn_ranger
Go ported or go home :) (unless you don't have the space or something)
If you are using a 1 ohm stable amp, get the dual 2 ohm coils
if you get 4 dvc 2 ohm subs, then you can wire to 1 ohm.
if you get 4 dvc 4 ohm subs, you can wire to 2 ohm.
headunit: pioneer 1400DVDsub stage: FI Q 15 D2sub amp: VVME inno-d 1500
voice amp: VVME 4 channel 4080.2nd battery: Soundquest SQB2000 2nd batterywiring:run of stinger ofc 4 gauge to 2nd battery
sky high and knu 0 gauge to bass ampsub box: custom ported box, 3.73^3 tuned to 32hz
rca's: stinger 6000 for basskicker 4 channel for voice
front stage:JBL gto608crear stage:renegade 6.2c
If using 1 amp and 4 sub, you need the dual 2 coils.
If using 2 amps and 4 subs, you need the dual 4 ohm coils.
There going in either an old school regal or caprice so room isnt a issue. As far as the amps I don't know that many brands that run the .5 ohm and I know there r tons of 1 ohm amps. Do u guys have any suggestions on amps
You need to find a 1ohm stable amp.
One that does about 3500W, like the audioque 3500.
If the amp is cheaper then 350 dollar it's not going to do 3000W except if going second hand.
I doubt you want to do electrical upgrades(putting in a HO alt and a big battery in the back) so go for 2 12's in a PROPER ported box and use a 1500W amp.
Edited by kirill007
Go ported or go home :) (unless you don't have the space or something) If you are using a 1 ohm stable amp, get the dual 2 ohm coils
If using 1 amp and 4 sub, you need the dual 2 coils. If using 2 amps and 4 subs, you need the dual 4 ohm coils.
You need to find a 1ohm stable amp. One that does about 3500W, like the audioque 3500. If the amp is cheaper then 350 dollar it's not going to do 3000W except if going second hand. I doubt you want to do electrical upgrades(putting in a HO alt and a big battery in the back) so go for 2 12's in a PROPER ported box and use a 1500W amp.
^ this
2010 F150 FX4
-18" AA Mayhem
-Crescendo BC3500d
-Pioneer GM-D9500F 4-channel
-2 Crescendo FT1
-2 Crescendo Neo Forte 6.5
-Pioneer AVH-P3300BT
-6000K HID Headlights/Fog lights
-All LED interior lighting
-20% tint on front windows, 1% rear windows, 5% windshield strip
-Big3 (XSFlex 0ga)
-DC Power 270XP
-Group 65 NorthStar AGM battery
Coming soon/plans:
-Build log
-Blacked out mirror reflectors
-Tinted tails/3rd brake light
Sealed box, deeper bass.... :No:
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
  • Who's Online   1 Member, 0 Anonymous, 938 Guests (See full list)
