loud and clear help
ALAMO695
Hey guys, i am currently planning a system for my 07 honda accord. From the system i want to maybe hit 150 (if posible), and be as clear and loud as posible, basically sql. I will be using the stock headunit on my accord, dont try and convince me to change it, as much as i want to change it i cant. The system will consist of the following components.
subs-x2 Dc xl m2 12's (tuned 32hz, subs facing front/rear seats down, ported, 80hz & down )
amp- Dc 5k @ .5ohms
front doors- 2 sundown neo pro 8's (per side,glassed doors, what should i cross them at?)
Tweeters front- 1 selenium st200 or suggest something (1 per front door, needs to be as small as possible)
Rear deck- 1 neo pro 8 (per side)
read deck tweeter- Suggest something
amp-sundown sax200.4
hu-stock
Processor- Rockford fosgate 360.2
Now my question is, can i get some midbass speakers and run them off the 200.4. I only what to use 2 amps (200.4 and dc 5k)
and i want to run the tweeters active.
i know its a mess lol just help me out a bit. Keep in mind i only want to run those 2 amps and want loud and clear music.
And what kind of electrical do you have planned for running 10k+ in an accord?
You HAVE thought about your electrical, right? Or are you gonna run 10k on a stock 90 amp alt.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Lol were did u get 10k+ from?
I get about 6k from the dc at 14 volts after rise of at least to 1ohm and maybe 1k from the 200.4 so thats 7k with some headroom
Btw of course ive thought about electrical, i have a mechman 270amp alt, a xs d5100 in the front 3 runs of pos and 3 runs of neg xs power cca 0 gauge and 2 xs xp3000's in the trunk
Well then, touché. Lol.
under construction
u hate c-fizzy?
Good luck with your 150....
If you're serious about any of this, keeping a stock head unit isn't a good idea. Seems to me you're stubborn and won't listen to suggestions even if good ones are given. You had a DC rep that was willing, but you blew that off. Good luck with your build, I'm sure you'll be on your own :)
  • 3 weeks later...
he you plan on being in a comp. i would if i was you change the head unit oem never gave me enough options.
If i had a Bentley or Rolls then i would keep the oem radio, lol.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
ok ...
I'd like to see how this would work running active 3 way up front and a rear fill off of a 4 channel amp ...
This install doesn't make sence to me at all ...
Sorry to bump an old thread, but I'd like to see the outcome on this ...
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
