SP4 Box Design
Shigshwa
I whipped up this box last night. What are your opinions on it, guys? It's for a Fi SP4 15, going into the trunk of my 05 Camry, and will go into the backseat of my friend's car for a while too.
and your port area should be in the port area range
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
not enough port. add some bracing, extra baffle..
edited... it's a 15... not an 18
if i remember correctly, the trunks of the camry's are HUGE. tall enough to not have to mount the sub facing up.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Move your sub to the other side away from the port if you stick with that design.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
I measured, and it's just barely bigger than what my trunk can hold. Why is it bad to have the sub facing up? And why do I have to move the sub more to the right?
because when the sub is facing up, a lot of the energy the sub produced goes into flexing the trunk lid, rather than going into the cabin. which translates into your trunk rattles like crazy, and it's not as loud in the cabin.
and move the sub over to the right so it uses the whole box and doesn't just unload into the port.
More box builds
Thanks for the points guys. I remeasured the trunk, and I'll redo the box for sub facing back, I have the height for it.
Here, guys. Is this fine? I know it lacks a few square inches in port area, but that should be fine, right?
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
