SP4 Box Design
Shigshwa
Looks fine to me.
IMHO people get way too hung up on port area per cubic foot vs. trying to keep the exit velocity of the air low enough to eliminate chuffing/turbulance.
I've done boxes with 9sqin port/cube up to 18 sqin port/cube with pretty high success.
If you tell me how much power you are running, I can figure out if you need more port or not.
Edit: and are you using the D1 or D2 sub?
What kind of power? Id try to get a slightly bigger box if you can
They recommend 3-5 cubic feet on the site. I'm putting 2000W on it.
The baffle thickness should be set to 0.75, if you are doing a double baffle which I would recommend, you should set the "# of extra baffles" box to 1.
Also a little more port area can't hurt you.
Finally the port width should be constant, if you dont know how to calculate the length of the parts I can give you some extra infos.
I didn't find a difference when I entered that for the baffle. As for the port, the box calculator did that for me already.
Looks fine to me.
2000 watts, D2 coils.
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
