I was pondering a few thoughts the other day after reading a few topics. The main one that concerned me was from a fellow competitor that I know and have met at a few shows. At first he started a thread about his sub getting hot and stinky on power that should not have even been a concern for the power that he was running, A few days after that he ended up blowing his amp. He has a good electrical, knows what he is doing and has plenty of competitors to hep him that are fairly close when or if he has and issues. I am NOT blaming STEVE or the DD-1, just would like a little more input on this question I'm gonna ask. I have the DD-1 and CC-1 and plan to use them. He and some other fellow competitors set their system using the DD-1, I'm pretty sure he was the only one that had issues. I then remembered he was running his amp @.5ohm so my question is:
When using the DD-1 since the subs woofers are not connected how does the DD-1 know where a clean signal is when running an amp at less than 1 ohm. Also if an amp like most kicker amps makes most of there power @2ohms would it defect for the clean signal @1ohm and then when you used it since you would be running it @2ohms would you technically be getting less power since you up the ohm load from where it was set?
Sorry if this is retarded question and doesn't make sense. I was just thinking and trying to come up with an answer for myself but I couldn't so I thought I'd ask the pros. I just can't think how it knows what ohm load it should set itself at.
Setting an amp is only one part of the equation. Even if an amp is sending a clean signal, the possibility of burning up gear is still very real even when everything is within power spec. The bigger issue I see when blowing gear over a bad signal is playing a sub out of the boxes tuning range. This can happen even faster in a spl built system where the range is very short and peaks hard at the desired tuning frequency. You can't expect a box to peak hard at 40hz and then play 20hz slappers and not expect shit to fall apart.
This
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
I'm not to concerned with his setting, I just wanna know the answer to my ohm load question for my self.
You can to .5 with good voltage at the amp, and if the amps isn't a POS, if you keep it cool, and if you aren't clipping
Edited by SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 865 Guests (See full list)
