Need electrical advice
I am currently taking my amps out of my car, getting bigge rones and 2 more batts but my question is I have this all hooked up 2 batts paralell multiple everything and I was curious what is the SAFE way to unhook the amps. batts here. I made a diagram of my trunk. RED line is POS and Black is NEG. What should I remove first? :o lol dont want a spark show today.
Also, if I leave the amps grounds attached to the factory ground will the bare end cause sparks if they touch the car? Thanks
pull all the fuses from your power leads.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ah, yeah that makes sense... facepalm. ALL of them or just the 2 at the amps? Also if if you don't mind me asking. Looking at this Diagram, what would be the most efficient way to wire 2 xp3000 batts. I do know what im doing somewhat i just over think things alot. Learning along the way so I dont waste $$
Put the batts as close to the amps as possible.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Pull fuses first, then grounds...................
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
  • Who's Online   0 Members, 0 Anonymous, 2014 Guests (See full list)
