not sure if this goes here but.. A few days ago i tested my system with the trunk open and yes it got way louder well today i spent about 2 hours foaming off around the false floor and wall and yet I'm still getting tons of air in the trunk I'm clueless as to where it could be going in at this is a cobalt I'm beating out of the backseat if anyone knows the designs on these cars or how i could track down how the airs getting back there would be very helpful at this point pics below id like to finish maken the backseat nicer and cleaner but not until i fix this problem
2009 Malibu LTZHead Unit - Pioneer AVH-P4300DVDSubs - 2 DC Audio m2 XL 15'sAmplifier - DC 5kWire - KnukonceptzAlternator - OhioGenBatteries - 2 XS Power 3100's, 1 d4700
Not familiar with car but in my g6 tons of air came through the 6x9 cutouts. And have you checked box for air leaks
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
I sealed off the 6x9 holes & yeah the box is fine also under the rear deck was sealed off a long time ago
Maybe have some kinda colored smoke or something silly like red smoke and just throw whatever it is in the trunk, "seal it up" and toss on some bass.. hopefully whatever it is is orderless or something along those lines. Even white smoke would work you just need enough to completely fill a trunk after you seal it.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
try a flash light
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
have you checked the side panels beside the back seats?
REP
try a flash light
Ill give that a try tonight
and no i didn't but i will now thanks
i found the problem it was part of the trunk deck that i thought was closed off by the frame i was wrong it goes the whole way into the trunk sealed it off sounds way better! i'm still trying the flash light thing just to make sure its all good
Edited by darksoul187
