Ok guys ran into some problems i dont think i can do 4 15's !!! we got in there today and here is the room i have to work with... 44 in or so going across 36 height is what i can play with should i ditch 4 15 hdc3's and go with like 2 18 dd 9500 or hdc4 or fi btl's or aa mayhems? if you have any ideas please let me know need to order tomorrow
You can do it. Just to some all-thread to brace the baffle in between the subs and make absolutely sure you cut your woofer holes right ;)
Mines built with only one sub in as im waiting on 2 others i ordered and my other recone comes tomorrow. Usually take a pic or two when complete. Ill try and post a pic tomorrow.
I was barely able to build outside of my vehicle. Any higher or wider and it would have had to been built inside.
16 cubes and center port
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
i can probably make 4 15's work...its just gonna be tight...REALLY tight...and id hate to get the subs and then have rip the base out and redo..lotta work for not lol i think we could get it close to if not just as loud with 2 18's as well have more freedom with the port to play with
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
you have more than enough room. Mine is 34 internal and I pulled it off.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
