its a good idea to.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
depends on how long they are and how you secure them...
a lot of people tape there aeros to allow change in tuning where as some glue and make aeros one solid unit making it stronger
it is nice to some how attach the aero to the box keep it from slapping around in there
R.I.P!
(Nov-29-2009)
92 explorer
current build
I seen some aero that you can screw into the outside of the box,,, my aero will be 8" diameter and 16-18 inch long.
theres proper AERO ports which are flared and then theres PVC pipe that we use as ports and call them aeros
heres box i did with 4 4" pcv ports and i had to glue and screw them to the outside the box there and then on inside thers a diamond inside where i drilled holes to keep the ports from moving around and then its screwed to the box to keep solid
this is an actual aero
R.I.P!
(Nov-29-2009)
92 explorer
current build
It depends. It's like asking if you need a double baffle - it can never hurt, but whether or not it's actually needed is application dependant
something along the lines of this should help
should help the port from bouncing up and down or left n right
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
