Audiopipe APK 5500 guts
theChief
looks like my audioque 3500d.1's i had.but alot different caps than my atomic 5000.1's hit us with the numbers.
4 hdc3-a 18's
2 aq 3500d.1's strapped
2011 usaci world finals,second place moddified 2000 to 4000
160.3 usaci out law.
you were able to turn it up 3/4 of the way becaues your preout voltage was ass. I dont know who started this misconception that sub level is supposed to be on 0 or 5 or whatever but im guessing they never checked the actual output voltage. Turn your sub out to 15. Im guessing you have an alpine. I'll bet that gets the full voltage out of it and then you can retune your amps. Id rahter my amps didnt have to work quite so hard to perform.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The head unit is kenwood & it has 4v preouts. I said the gain made it 3/4 before clipping. NOT that I was running it at 3/4. It's plenty powerful right below 1/2. & I'll test with the sub level at full but I know for a fact that will clip the signal from the HU
My voltage stays right at 14 at 1/2 gain & the amp stays ice cold. I don't consider that over working it.
i didnt think sub output level could cause clipping?...i am confused or misinformed here?..i know HU volume can but didnt think sub out had anything to do with the HU causing clipping...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
something seems off
I bring my hu to its highest unclipped signal (4v pre outs) and I don't even get a 1/4 turn on the gain to reach full power unclipped
same here.
OP, i would turn the sub level to 0, bass boost to 0, and make sure the HU Eq settings are at 0 as well.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
you can set the sub level on the HU to whatever you want, but once you scope the pre-outs for the sub, 50hz or lower tone being used, you will find that you cannot turn the volume knob as high, and will cause clipping earlier.
General you want to set all eq settings to 0, and sub level to 0 when finding what your Hu will clip at xx volume.
HMU!!!
95 Bonneville SSE
