Does a port need to be small enough to have compression?
IMO it's tuned to high and the volume is too small. Even RE recommends 4ft^3 with a 33hz tuning, but something like 5ft^3 with a 25-27hz tuning will work better and not be so peaky. Just don't expect much upper end response with this sub, it's just a lathargic beast with an uber low Fs and high moving mass to match. Try putting it in a 3ft^3 sealed box and see what you think.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
So what could be the reason for there being almost absolutely no bass except for one song??
A car peak around 45 hz mixed with bass boost with the type of person who has to asks the types of questions at the start of this thread tuning the amp.
btw i have yet to find a single copy of that song that's been clean so... you most likely are getting the illusion of louder from distortion.
Asking a question doesn't make me a moron. I tuned the amp with the DD-1, set LPF to about 4 hz below tuning freq, and subsonic to about 60 hz above tuning freq. btw, I don't know where your looking but I had no problem finding a clean copy of that song...
Ty sir. Sealed box was an option to get more of a range but I wasn't sure how that sub would be in a sealed box. Now I haven't done much as far as sealed boxes, so what would you do for amp tuning? LPF down low subsonic up high?
what...why the hell would you put the subsonic at like 90hz? i hope to god you mean you put the LPF at 90hz and you put the subsonic at 30hz or whatever.
subsonic cuts off LOW frequencies, like 10hz. lpf cuts out HIGH frequencies, like 100hz.
box is tuned too high, box is too small, and a cabin peak all attribute to exactly what your problem is.
hahha
I'm not getting bass!!
SUBSONIC @ 90hz
LPF @ 80 hz
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
in my experience, smaller ports have a wider musical range, and larger ports tend to get "peaky" and slam a more narrow frequency range
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
Not true. Design issue, not the port size.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
If you want to see what the effect of a smaller port is then jam a peice of MDF in the port to make it narrower.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
