plan for the worst. the wire could get beat up if ran under the car or cut on the hole in the firewall. shit happens.
I actually know someone that this just happened to. Bye Bye to 4 or 5 D-3100's and the 3400 up front :cray:
welding cable has some of the best insulation ive seen for how thin the insulation is, but say it rubs on something or something gets kicked up into it then the insulation could wear down and create a short, this goes for any wire, and you never know what could happen. worst case scenario you push your sub a little too hard and short a coil which in turn overloads the amp and causes an internal short(happened to me unfortunately) without a fuse the wire will continue to carry the current untill the wire gets so hot it melts and could cause a fire
Bc it's welding cable or just in general? I plan on using techflex for the long runs.
Just in general. The guy I mentioned had his car on a lift, which settled overnight. His wire got crushed in the middle between the lift and his frame which caused a dead short to ground.
as N8 already posted you should have a fuse between the front batt and the alt
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
did you also include a battery isolator? maybe one is not needed.
Edited by stipek
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
did you also include a battery isolator? maybe one is not needed since everything is wired in series.
No he does not need an isolator and it is in parallel, not series.
Edited by Lbox88
FUCK dude! That sucks monkey balls!! I've wired about 20-30 amps/cars and that hasnt happened to me. But I wanted to do my RIGHT this time, because I have expensive equipment and extra batteries.
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
  • Who's Online   0 Members, 0 Anonymous, 1475 Guests (See full list)
