I'm sure that this topic has been posted before, but I'm curious about something. I've seen and heard a lot of guys when they do their + and - runs through their vehicles, they take the Negatives all the way from their battery. Isn't it easier to ground to the frame(plus a huge savings in wire for cost) like I've done here:
Maybe it's not as easy for some guys since might not have a full size full frame truck like mine. Grounding directly to the frame(clean contact point) is a good idea right?
it is cheaper yes but not more efficient.... a run directly to battery is a direct route and doesnt have to go through all the parts that make up a vehicle to get back to battery
R.I.P!
(Nov-29-2009)
92 explorer
current build
^^This, you gain Db's if you run your ground to the neg on your battery.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
watch this it will help a lot
Thank you drew (noobtastic) for making this.... hell it should be stickied somewhere
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
If the ground from the front battery and alternator are bolted to the SAME frame that I've made my new ground, isn't that the same thing? The frame of my truck seems like a great place for the ground that I've made.
Almost all frames have some sort of resistance and copper is a much better conductor than steel I prefer to run seperate grounds. The frame ground is just in case he pulls more amps than his ground wire can handle before resistance goes up he's got the chassis ground to compensate
HOLY SHITBALLS.
That video is old and I didn't know anybody ever watched it. Thank you Uhoh_45 for the link and the compliment that just made my night. I don't have sound at work, but when I get back I will have to rewatch that video.
-Drew
**Watch it, Three years apparently makes quite the difference I got a kick out of hearing myself and especially seeing myself at the end. Whata joke. I may end up taking this video and reshooting it in the daytime with better audio and pinning it in the electrical section.
Edited by Noobtastic14
uhoh_45 said:
Also, A framed car is much different than a unibody car.
If you have a solid frame rail from the front to the back with both your engine bay grounds attached to it in the front and rear battery/amp grounds attached in the rear that will be as efficient as you can get without running a dedicated run. A unibody is horrible for conductivity and does not operate the same way a frame rail does.
-Drew
  • Who's Online   0 Members, 0 Anonymous, 2044 Guests (See full list)
