I got a Ohio generator 270a hairpin alt to replace my stock one a few months ago and lately I see people talking about running power and GROUNDS from your HO alt. Mine has no ground studs... I don't know why. I caled ohio gen and they said there is no ground stud on them.??? Is this ok? seems strange from what I have been reading... Stock batt is is the trunk.
you proboboly could just ground it to a mounting bolt, honestly i couldnt tell you because i havent messed with them before
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Not sure. i know there is no designated ground post on it. I mean it's alot of work and wire to run 1-2 runs of 1/0 for ground to my batt in the trunk if I did not need to.
I got 2 runs of power already and it BARELY fits. 2 door Cobalt (pontiac pursuit)
go underneath the car
The alt grounds through the mounting bolt to the engine block..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
So being a unibody car where the stock battery is in the trunk, would I benefit at all by running a run of 1/0 from a mounting bolt to the negitive battery terminal in trunk?
Technically considering where your battery is located, thats part of your big 3 that you failed to do it sounds like. Do you have a ground going from the engine block to the battery in the rear?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
this.
a ground from the alternator mounting bolt to the battery is/should be part of your big 3.
no the alt should not have a ground stud on it.
Ummmmm nope. Just beefed up th eon efrom engine block to body. :peepwall:
So i should have 1 or 2 runs from the alt mounting bolt to my batt correct? shit theres another 35 feet of 1/0 i dont got now :S
Any advice for running 1/0 knu under the car? have no room left inside for 1/0
EDIT just got 40 ft of knu 1/0 on the way. will be oing this late next week 2 runs :)
Edited by Amart88
  • Who's Online   0 Members, 0 Anonymous, 1671 Guests (See full list)
