I got a Ohio generator 270a hairpin alt to replace my stock one a few months ago and lately I see people talking about running power and GROUNDS from your HO alt. Mine has no ground studs... I don't know why. I caled ohio gen and they said there is no ground stud on them.??? Is this ok? seems strange from what I have been reading... Stock batt is is the trunk.
you proboboly could just ground it to a mounting bolt, honestly i couldnt tell you because i havent messed with them before
Not sure. i know there is no designated ground post on it. I mean it's alot of work and wire to run 1-2 runs of 1/0 for ground to my batt in the trunk if I did not need to.
I got 2 runs of power already and it BARELY fits. 2 door Cobalt (pontiac pursuit)
go underneath the car
The alt grounds through the mounting bolt to the engine block..
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
So being a unibody car where the stock battery is in the trunk, would I benefit at all by running a run of 1/0 from a mounting bolt to the negitive battery terminal in trunk?
Technically considering where your battery is located, thats part of your big 3 that you failed to do it sounds like. Do you have a ground going from the engine block to the battery in the rear?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
this.
a ground from the alternator mounting bolt to the battery is/should be part of your big 3.
no the alt should not have a ground stud on it.
Ummmmm nope. Just beefed up th eon efrom engine block to body. :peepwall:
So i should have 1 or 2 runs from the alt mounting bolt to my batt correct? shit theres another 35 feet of 1/0 i dont got now :S
Any advice for running 1/0 knu under the car? have no room left inside for 1/0
EDIT just got 40 ft of knu 1/0 on the way. will be oing this late next week 2 runs :)
Edited by Amart88
  • Who's Online   0 Members, 0 Anonymous, 723 Guests (See full list)
