okay so this JL 8 inch sub(http://www.jlaudio.com/8w1v2-4-car-audio-w1v2-subwoofer-drivers-92070) says it should be tuned to 38.0 hz well it has a circle port, but I wanna do a square port so below is the frequency of 38.55 going to make a big difference?? and also I calculated is as one box cause jl's site only gives you specs for on one box, the the port would be like a t shape inside the box
Holy .75 ft^3 of bracing displacement batman. That's more than the net internal volume you've left for yourself. And yes, 38.55Hz would be close enough to 38Hz but I don't see why you're tuning that high or using these specs
JL's site recommends tunning the box to 38hz and in would be a brace in the middle,
and the .75 is the thickness of the sheet of mdf??
Edited by Cameronmyers74
Even so, you do realize that a value of .75 in the bracing displacement section means three quarters of a cubic foot. Imagine a block of wood 12" tall by 12" wide by 12" deep. You're saying that you'll be using 3/4 of this chunk of wood for bracing.
