Cameronmyers74 Posted April 12, 2012 Report Share Posted April 12, 2012 okay so this JL 8 inch sub(http://www.jlaudio.com/8w1v2-4-car-audio-w1v2-subwoofer-drivers-92070) says it should be tuned to 38.0 hz well it has a circle port, but I wanna do a square port so below is the frequency of 38.55 going to make a big difference?? and also I calculated is as one box cause jl's site only gives you specs for on one box, the the port would be like a t shape inside the box Quote Link to comment Share on other sites More sharing options...
Joe X Posted April 13, 2012 Report Share Posted April 13, 2012 A T port is for two subs. is that the case? Quote Link to comment Share on other sites More sharing options...
Cameronmyers74 Posted April 13, 2012 Author Report Share Posted April 13, 2012 Yes, i will be using two subs, each will have a chamber but the t-port will tie the two together Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 13, 2012 Report Share Posted April 13, 2012 4sq in of port?!? Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Cameronmyers74 Posted April 13, 2012 Author Report Share Posted April 13, 2012 okay I'm asking is the box being at 38.55 hz is close enough to 38.0 hz?? and thats what came out when I put in the numbers Quote Link to comment Share on other sites More sharing options...
Sergeant_Skyrim Posted April 13, 2012 Report Share Posted April 13, 2012 Holy .75 ft^3 of bracing displacement batman. That's more than the net internal volume you've left for yourself. And yes, 38.55Hz would be close enough to 38Hz but I don't see why you're tuning that high or using these specs Quote Build in progress Link to comment Share on other sites More sharing options...
Cameronmyers74 Posted April 13, 2012 Author Report Share Posted April 13, 2012 (edited) JL's site recommends tunning the box to 38hz and in would be a brace in the middle, and the .75 is the thickness of the sheet of mdf?? Edited April 13, 2012 by Cameronmyers74 Quote Link to comment Share on other sites More sharing options...
Sergeant_Skyrim Posted April 13, 2012 Report Share Posted April 13, 2012 JL's site recommends tunning the box to 38hz and in would be a brace in the middle, Even so, you do realize that a value of .75 in the bracing displacement section means three quarters of a cubic foot. Imagine a block of wood 12" tall by 12" wide by 12" deep. You're saying that you'll be using 3/4 of this chunk of wood for bracing. Quote Build in progress Link to comment Share on other sites More sharing options...
Cameronmyers74 Posted April 13, 2012 Author Report Share Posted April 13, 2012 So what would I enter for bracing then?? Quote Link to comment Share on other sites More sharing options...
412 CVX Posted April 13, 2012 Report Share Posted April 13, 2012 use round ports and get at least 8 sq inches of port per cube. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
