BangInTheTrunk Posted April 15, 2012 Report Posted April 15, 2012 Not sure if I worded that right.. I see a lot of people who compete with sound deadening material on they're doors and the lining of the trunk.......I was wondering.. just how much does this help and what would be a good brand to go with.. locally I can only get one brand and it is EXTREMELY overpriced..
optical Posted April 15, 2012 Report Posted April 15, 2012 For most its the annoying rattle they are trying to avoid rather the improvement on the meter. I believe i have seen it go both ways for the meter as well. Everyone will recommend secondskin because well its among the best.
kirill007 Posted April 15, 2012 Report Posted April 15, 2012 secondsking or SoundDeadenerShowdown Thinking is the root of all problems... You ALWAYS get what you pay for.
audiofanaticz Posted April 15, 2012 Report Posted April 15, 2012 Ive used both secondskin damplifier pro 80mil and audio technix 80mil, I like both so far however price point wise the audio technix stuff seems to be a lot more bang for your buck. Also have been amazed that Im having no adhesive issues with the stuff and it is sticking fine when its being installed in 30degree weather! Some of your asphalt based deadeners that are even cheaper priced yet wont let you do that.
Dangrebel Posted April 15, 2012 Report Posted April 15, 2012 I gained more db's with it and my roof doesn't rattle anymore 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
BangInTheTrunk Posted April 15, 2012 Author Report Posted April 15, 2012 Thank you thank you! So it helps with that annoying rattle also?? Good. I can't stand to hear cars rattle from the slightest amount of bass. Any suggestions on a web site I can order this deadening material from?
VIPmeetSPL Posted April 15, 2012 Report Posted April 15, 2012 google up audio technix 60 or 80 mil should come right up if thats the one ur looking for if second skin then look up john here on the forums
Second Skin Rep Jon Posted April 15, 2012 Report Posted April 15, 2012 Rattles can actually be killed without the use of sound deadening. Find out what exactly is rattling and isolate it from making contacting with another panel. For example, just a bit of closed cell foam between the plastic trim and the sheet metal will work and cost ya next to nothin. Of course this is just if you are trying to kill rattles. Sound deadening does several things when installed on the sheet metal... but I'm not going to dive into that right now. Have a question about Second Skin? E-Mail me!
VIPmeetSPL Posted April 16, 2012 Report Posted April 16, 2012 Rattles can actually be killed without the use of sound deadening. Find out what exactly is rattling and isolate it from making contacting with another panel. For example, just a bit of closed cell foam between the plastic trim and the sheet metal will work and cost ya next to nothin. Of course this is just if you are trying to kill rattles. Sound deadening does several things when installed on the sheet metal... but I'm not going to dive into that right now. what he said this man knows his shizznit
