GOTTA GET TO 150 O.M.G. HELP!!!!
along with what n8 said could try a layer of fiberglass resin on the inside.. sand it smooth might gain ya a few tenths
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
thanks guys, im gonna do some steel bracing, and do some fiberglass resin and it should do the trick, i might lose a little db because i am gonna extend my ports tuning @ 33hz, i like them lo-lows!!!
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
btw, new alternator going in as we speak!!!
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
those things will gain you small amounts. you need a leap. you still need to answer alpine's questions. i dont understand why you didnt yet. and we need a picture of the box inside the car.
its cool I'm waiting lol
Ya the box needs work bracing will help a lot upgrade to areo ports but the main question is how is it wired per amp
4 inches off the back door is pretty close anyway to test it pushed back some do you have access to a meter?
Sorry ALPINE, I cant get a pic of the box in the car, camera is broken, subs are dual 2's each woofer , so realized each woofer seeing 1500 ea, wired @ 4ohms, lbox88 helped me with some pics....subs up ports back....
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
i did slide box up a lil off the back door, and it made a tremendous difference, gonna do some steel bracing/resin flared ports...also whats the closest i can have the end of the ports to the inside box wall?
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
ok so he pmed me there dual 2's only 1500 rms each if that... being there dual 2's you would be better off running just 1 amp 1 ohm to each channel still 1500 rms per sub.. hopefully
as for "steel bracing" all thread rods are cheap and work like a dream.. you already noticed a difference when moving the box back i would not go closer than 6 inchs to you back door
Flared ports will give you a slight gain but a gain is a gain and they look better
the closest you should go with the ports off your box wall is the size opening of your port so if you have a 6 inch port you need to stay a min of 6 inches away from the box wall if there 4 inch ports min of 4 inches and so on
  • Who's Online   0 Members, 0 Anonymous, 374 Guests (See full list)
