OrionStang Posted April 21, 2012 Report Share Posted April 21, 2012 Why are you guessing? Read the manuals for your equipment, it should say what the slope is, and if its adjustable. Also, I would suggest leaving the amp on "through" and controlling the hpf on the deck only. Unless you have a cc-1, then do the opposite. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Trey_Dog650 Posted April 21, 2012 Report Share Posted April 21, 2012 they have these bass remover things that you can wire into your speaker and they supposedly remove the lower notes Quote 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head. Link to comment Share on other sites More sharing options...
Decaf Posted April 21, 2012 Report Share Posted April 21, 2012 there are no brick wall stops... crossovers are sloped. using 120/100hz@18db will yield basically no bass below 50/60hz Quote Link to comment Share on other sites More sharing options...
Jessica Posted April 21, 2012 Report Share Posted April 21, 2012 I'm running my mids around 65hz on my ep2x, everything below is -18db. That will change when i get my mid-bass speakers. I only have it that way cause drums like tom's and snares sound thin and tinny if i don't. Not to mention male vocals sound fuller and warmer that way too. (guys like Garth Brooks and Josh Turner dip down lower than you might think. Plus my mid are good to 50hz. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
zxsonnyxz Posted April 22, 2012 Report Share Posted April 22, 2012 You mentioned prosessors. Those should be able to cut pretty steep. The Mosconi DSP I want suposedly does up to 60db/okt. Quote STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
Guest Posted April 22, 2012 Report Share Posted April 22, 2012 you should probably get better mid drivers then. or deaden your doors a bunch Quote Link to comment Share on other sites More sharing options...
TRON Posted April 22, 2012 Author Report Share Posted April 22, 2012 Yeah I figure Its time to work on the doors, and maybe upgrade or get a second set of mids? Quote Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s Link to comment Share on other sites More sharing options...
Guest Posted April 22, 2012 Report Share Posted April 22, 2012 if you're looking for good midbass, dont use coaxials. you need to use component systems. or you could buy separate mid bass and super tweets. from everyones ranting and raving, crescendo's midbass drivers seem to work pretty well. Quote Link to comment Share on other sites More sharing options...
jocvtrhythgd Posted April 23, 2012 Report Share Posted April 23, 2012 When the woofers are a' flexin' I don't care but when they aren't... Tiffany & Co Outlet Tiffany & Co Sets Tiffany & Co Rings Tiffany & Co Bracelets Mac Cosmetics Outlet Quote Link to comment Share on other sites More sharing options...
TRON Posted April 23, 2012 Author Report Share Posted April 23, 2012 (edited) I don't have my subs on full all of the time...I listen to music with low bass levels. Edited April 23, 2012 by TRON Quote Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s Link to comment Share on other sites More sharing options...
