Where do I go from here?
That's kinda what I was getting at but nobody besides yourself bothered to read it seems..... Thanks for your input. I'm going to install the 250 and keep it down until I add grounds tomorrow and get my 300's I ordered.
EDIT: says nothing about amperage draw.
AP-15001D
RMS @ 4 Ohm (<1% DISTORTION) ....................................... 600W
RMS @ 2 Ohm (<1% DISTORTION) ....................................... 950W
RMS @ 1 Ohm (<1% DISTORTION) ....................................... 1500W
Input Level ................................................................................ 0.2 ~ 5V
Frequency Response ............................................................... 8 ~ 180Hz
LPF .......................................................................................... 40 ~ 180Hz
SUBSONIC Filter ....................................................................... 5 ~ 50Hz
Bass Boost Frequency ............................................................. 30 ~ 80Hz
Bass Boost Level ..................................................................... 0 ~ 12dB
THD at 4 Ohm load 30% Rated Power .................................... <0.2%
Signal Noise Ratio .................................................................... >70dB
Best Efficiency ......................................................................... >85%
Minimum Load ......................................................................... 1 Ohm
Optional Remote ...................................................................... YES
Bridgeable with Same Amplifier ............................................... YES
Overload Protect System ......................................................... YES
Short Circuit Test (max. power) ............................................... PASS
Overheat Protect Temperature ................................................ 80 ̊C/176 ̊F
Components & PCB ................................................................. SMT & Double Side Board
Transparent Isolation Connector .............................................. YES
Optima Redtop Under Hood
Vmax CT800 Outback
Big6?(lol) 0/1 KnuKoncepts
2x 15" RF T1's in 7.7cuft @32hz
Audiopipe aqx3500.1d
Pioneer DEH-5000UB
I have no problem buying a volt meter but not until I add a second battery.
Vmax CT800 Outback
Pioneer DEH-5000UB
Its not really rocket science .. you have 2*100A = 200A ... then add how much your mids'n'highs amp fuse rating is, a 250 amp fuse will probably be the right one for you system
Did you or did you not read the post stating I heard the 100amp fuse was slightly underrated.
So I would need to find the max amperage draw which I have not been successful at thus far.
Ah i see, well i didnt find any official current draw, but it seems a few people them have been using them with 100A fuses and they haven't blown.. really i would expect them to need a 150A fuse each if they where 1500w amps which are 85% efficient.. The 300A fuse will be the best for them :)
My System (in VW golf/Rabbit mk2)
(1) Hifonics Brutus 2010D @ 1ohm
(1) Hifonics Zeus 440 Mids'nhighs
(3) JBL W10Gti subs
(2) JBL GTO838
(2) JBL GTO936
(1) run of 3/0 Gauge ofc
(1) Ac Delco120ah 850cca battery (front)
(1) Ac Delco 45ah 330cca battery (rear)
(1)Sony Gt630ui hu
34hz tuning
Lol $8 for a fuse. I picked up 10 250s from audio savings for like $10
By the way I am finally seeing 14.4 volts while driving with both amps on just not really producing sound.
Vmax CT800 Outback
Pioneer DEH-5000UB
You have a 75 amp alt you aren't going to be able to run 2 ineffecient 1500w amps.
Your amperage draw will be above 200-250 amps, see how that is 125-175 amps too little, not adding in the power your car needs to run by itself.
You NEED a high output alternator.
While that's a great point, I need to buy the things that are readily available to me right now and save for the alternator in the next month or so. Mechman quoted me <$600 and I just can't afford that at all right now so unfortunately I will be looking for other avenues.
Vmax CT800 Outback
Pioneer DEH-5000UB
  • Who's Online   0 Members, 0 Anonymous, 1672 Guests (See full list)
