That sounds great man. Pretty cool for him to help you out like that. I feel sorry for that car facing subs up lol.
Thanks man
Well, I have more Audio-Technix laying around if needed lol
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Good luck on the new box! I'm anxious to see what you can do with those 15s!
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Thanks man :)
2003 Kia Sorento
Team Subsonic Lows
I suggest u run the voltmeter wire together with the signal cable, or at least on that side. It might get interfered with from the power. But there is no way enough power in the voltmeter wire itself to every influence the signal cables. ]morning.gif
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Turn it's probably the turn on wire(my headunit's remote wire doesn't work anymore, so I have to manually turn on my amps) that is causing that then, but I don't understand why, I thought the purpose of the voltmeter was to read what's coming from the power wire since it's going to be attached to it anyways
2003 Kia Sorento
Team Subsonic Lows
So, after measuring and measuring, I finally came up with a new box design that I can actually slide through the backseat.
Slightly bigger, higher tuning, and same amount of port, which should still get loud
The subs are going to facing up, and the port forward
Glady with the new dimensions, I have leftover dowels, and the other half of the sonotube I didn't use, so I just need more mdf, though now I'm thinking of using this instead, gonna cost me $15 more, but it's lighter, and everyone says it works just as well as mdf, and is easier on the tools
3/4 birch plywood
http://www.lowes.com/pd_37985-99899-37985_0__?productId=3658234&Ntt=birch+plywood+3%2F4&pl=1&currentURL=%3FNtt%3Dbirch%2Bplywood%2B3%252F4&facetInfo=
Opinions anyone?
2003 Kia Sorento
Team Subsonic Lows
Will it fit through the door? lol...
And birch is kickass. My box is 1/2 russian birch and it's super light, and rigid enough for me to stand on.
I have 33 inches of clearance from the bottom of the back seat when removed and not touching the handle on the ceiling
Only thing I may have to do is remove the door panel
I'm considering birch due to weight, current box I built is too heavy for me lol
2003 Kia Sorento
Team Subsonic Lows
So another small update
Another sketchup of how the box will look like
-Made sure to keep the 15's out of the of the way but 1 inch away from the wall
- 4 2' inch vertical dowels, which will be utilized from leftover dowels
- 2 2' horizontal dowels
- Port holders to secure the port, and for more vertical bracing
2003 Kia Sorento
Team Subsonic Lows
