XS Power
So i ordered a d3400 from crutchfield (every one else was out of stock) and it just came today but instead i got the s3400 is there any difference between the 2 should i send this one back.
2015 F-150 Platnuim
As said above the S3400 and D3400 are the same exact battery. Only differences are the S3400 has red decals and comes with automotive posts. The D3400 has blue decals and comes with hardware to run ring terminals. If you would rather have the blue decals and run it under the hood with automotive terminals, then you can purchase a set of 580 SAE Automotive Posts.
If you are running side posts then you may want to look at the 551 or 555 iBar kits. If you have any other questions just let me know.
From here:http://www.stevemeadedesigns.com/board/topic/98506-d3400-and-s3400/
