45 degree port corners??
How necessary are 45's in a slot port corner?? What exactly would be the benefit of having them, or negative of not having them. As a side note, it'll be a low power scenario (300w) and either 2 10's or 1 15. Thanks!
2000 Jeep Cherokee
15" Alpine Type R box build coming soon!
Possabilitys that i have seen/heard.. It can help increase air flow, a guess bracing to a point, can lower internal volume (also can change tuning). Can help with score, can make it worse. Can sound better to ear but worse on meter, could sound worse to ear but better on meter,
About it i think..
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
It's not necessary. mainly it just helps smooth out airflow through the port. but with a low power setup like yours, it's not really that important. more than likely you won't hear a difference at all.
More box builds
I'm with captain stupid.
they increase the efficiency of the port, same as a flare does on PVC
well in some setups it does, some it actually loses efficiency. its like aerodynamics, you can guess it to a certain point, but some things you just have to test in your particular application.
Owner of BigAss Ports
They keep the port the same width as it transitions around the corner. The port actually widens and shrinks and ideally you want to keep it the same width which is where the corner piece comes into play.
Unless you are doing something high power or playing with a meter it won't make much of a difference at all to the ear.
-Drew
detail.gifI am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. detail.gif
uhoh_45 said:
dont be a pussy P give the jeep to drew
  • Who's Online   1 Member, 1 Anonymous, 1540 Guests (See full list)
