That looks awesome!! Good concept air flow should be really good to hit them low notes :good:
Edited by Legion420
03 Dodge Caravan SE
Alt. Stock
Head: JVC KD-A615
AMP: BOSS PH4000D Phantom Series Class D Monoblock
Mids-Highs:
2 JVC CS-HX6947X 6X9 490w
2 JVC CS-V6937 DRVN 6X9 310w
2 JVC CS-V527 DRVN 5-1/4" 200w
Box: 2 Q Power 15" Woofers New Deluxe 2,000watts each
Carpeted and not ported
My small budget build
http://www.stevemead...n-budget-build/
Looks like third time is the charm with this design.... make sure you duck when the arm rest comes resting in the front seats. Good build sir.
I may not slam trunks anymore....but my trunk still slams.
Does the plexiglass add anything to the sound or just looks? I'm running an old mix box with the plexiglass back . Just wondering if it helps or just for display?
Tested it today but there is no way to "temp" a box in with an SMD and 3500watts on it. It just wants to pull the box apart. I tell you what though, the tone is DEEP and powerful.....great range. And that was on the BENCH. Wait till i get me some cabin gain.
once it is fitted and the hole is proper.....i will pull the box out AGAIN and do my bracing and get the bolts to hold the sub in properly. Then i can finally put it in and try it out!! Its all about prep work here. I can't rush it.
One more thing - reminder of what i already said. The sub is off center for a reason. There is a support bar at the bottom of the opening that is about 3" high. I raised the sub up as high as i could to clear that. Its still not fully cleared but its not too bad.
I usually do my best cuts old-school style but i hit some layered metal and had to put the snips down.
thats right ya'll the old jig saw with metal blade. Made SHORT work of the task at hand.
Follow my Tweet (Twitter)
of course i am going to spend time cleaning up the hole and then sealing off the baffle. This thing is gonna SLAM. All other IsF, 250 and 350 better watch out lol
That's pretty incredible Mr Meade, holy shxt balls, I wish I could do that in my gto but there's a gas tank in the way. Is there anything you can't build? Doubt it!
  • Who's Online   0 Members, 0 Anonymous, 3059 Guests (See full list)
