What is it about playing under the tuning of your box that is hard on the sub?
This possibly resulted from it: 528870_10151716866960192_721285191_24779752_1723910396_n.jpg
E34 540iT/6
It's almost like free airing it, you will reach any subs mechanical limits much faster playing under your tuning. You probably bottomed out the coil.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
playing under tune causes the sub to unload ,maxing out excursion= hard on spiders, surround,voice coil if it bottoms , during this the cone can distort ,tear, hit the winding
glad to see you made it to the forum.. i had a feeling you would chime in on this. there are some real knee slappers that happen in this sub forum.. so be prepared.
I played this sub under tuning fairly regularly, but it barely moved with the amount of power I had on it. And my set up has been o scoped and everything, minimal clipping on the sub. I don't understand how it separated..
E34 540iT/6
What kind if sub was it?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
ive seen alot of hdc coils go bad on low power
i have 2 burnt coils in the closet 1 died on a cadence 1200w and the other died on maybe 1400w
both coils came unwound
and 1 of them ripped the triple joint
in my book AQ or should i say SOUNDQUED uses ultra cheap softparts n material
Cause its not moving enough to cool itself off on low power.
Maybe youve had bad luck with them, my friend is running two hdc3 12s copper coils on a 3.5k and they take the power just fine, box isnt small either tuned to 30hz. Box was designed by bassheadsent.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
  • Who's Online   0 Members, 0 Anonymous, 1462 Guests (See full list)
