Battery Under hood or In Trunk?
Ok, I'm looking into buying either a XS D2700 or an XS D3100 battery.... Issue is that I am only allowed one battery in the class that I am running. I can barely fit the D2700 in the stock battery location, and the D3100 is way to big to fit.
Question is: Should I just deal with the D2700 and keep it in the Stock location, or go with the bigger D3100 and just put a distrobution block under the hood and run the battery in the trunk?
Thanks guys
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
id say run a distro block and go with the 3100 that way if you ever upgrade what you got or switch classes youve already got your wires and everything done and can put another bat under the hood
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
My concern with it being in the back and only running 1 battery is it being so far away from the alt, I'm not sure you would get a steady flow to the batt. I'm thinking your amps would discharge your batt faster then it could charge being so far away. I could be wrong I have been drinking with my wife since 6 LOL.
People run rear battery only in hot rod and race car type applications all the time, the battery getting good current is more dependent on run large enough wire fom up front to that. I run a rear mounted battery in my Trans Am and have never had an issue. Places like Summit sell kits specifically for relocating your battery to the trunk.
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
In the class I can only run 1 run of 1/0 which is done, Yes its farther from the Alt, but at the same time its closer to the amp.
I run a rear batt in my drag truck but it's not being beat on by thousands of watts constantly.
I think I'm just gonna put the D2700 up front.... Only running a red top right now, so I can't wait to have double the storage capacity! Hopefully see some rise in the Numbers
Definately put the battery under the hood. I wouldn't ever reccomend just running a battery in the rear unless you want to burn up your alt. If you could run 8-10 runs of 0/1 then it may not be a problem, but since you can't your going to thank yourself for keeping it in the front of the car.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
^ x2 didnt know that you could only run 1 run of 1/0 at the time
Just go ahead and put the 3100 in the back. And later on if you decide you can put the 2700 back up front, then have 2 batterys when your not competeing
02 Civic Si
Stock Alt
Kicker 0 gauge wire
Shuriken SK-BT80 Battery
JL Audio J2 320.4
Planet Audio BB 2400.1
Fi BTL 18 ufo motor
My 02 Si Build! http://www.stevemead...__fromsearch__1
  • Who's Online   2 Members, 1 Anonymous, 497 Guests (See full list)
