beaker Posted May 19, 2012 Report Posted May 19, 2012 I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly.
TheNewbie Posted May 19, 2012 Report Posted May 19, 2012 I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly. Not really abuse when your under powering them by 100 watts each Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Jordan Kushner Posted May 19, 2012 Author Report Posted May 19, 2012 I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly. Not really abuse when your under powering them by 100 watts each It's not the 100 watts, it's that you aren't supposed to wire that ump under 1.5 ohms
Jordan Kushner Posted May 19, 2012 Author Report Posted May 19, 2012 its perfectly fine, i deal with JL on a daily basis. it is either user error or installer error Do you know a way to put 600 watt RMS to each sub with my current amp?
littlebuck1919 Posted May 19, 2012 Report Posted May 19, 2012 its perfectly fine, i deal with JL on a daily basis. it is either user error or installer error Do you know a way to put 600 watt RMS to each sub with my current amp? i do....u could buy two 600rms amps....or an amp thats good for 1.2krms at 1ohm or 4 ohms....that'll get u the correct amount of power.... Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586 i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol 6/18/82 - 4/17/12 R.I.P. to my sister Shana
TheNewbie Posted May 19, 2012 Report Posted May 19, 2012 I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly. Not really abuse when your under powering them by 100 watts each It's not the 100 watts, it's that you aren't supposed to wire that ump under 1.5 ohms lol it is that.. He said he abused his subs not amp there skippy Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Jordan Kushner Posted May 19, 2012 Author Report Posted May 19, 2012 I run 2 JL 12w6v2's on a Slash 1000/1v2 @ 1ohm and I've never had an issue, and I abuse those subs like its my job. I'm guessing something was wired wrong, or gains wherent set correctly. Not really abuse when your under powering them by 100 watts each It's not the 100 watts, it's that you aren't supposed to wire that ump under 1.5 ohms lol it is that.. He said he abused his subs not amp there skippy Exactly, he abused his subs with his amp set to 1 ohm. Read more carefully
Jordan Kushner Posted May 19, 2012 Author Report Posted May 19, 2012 its perfectly fine, i deal with JL on a daily basis. it is either user error or installer error Do you know a way to put 600 watt RMS to each sub with my current amp? i do....u could buy two 600rms amps....or an amp thats good for 1.2krms at 1ohm or 4 ohms....that'll get u the correct amount of power.... I really didn't want to get rid of my 1200/1 Fits perfectly in my amp rack
Baydestrian Posted May 19, 2012 Report Posted May 19, 2012 Like stated before, JL amps do the rated power from 1.5-4ohms, wire your subs to 4ohms and you will get 1200rms at 14.4v. So your voltage has to be stable. 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Toofast4u Posted May 20, 2012 Report Posted May 20, 2012 Like stated before, JL amps do the rated power from 1.5-4ohms, wire your subs to 4ohms and you will get 1200rms at 14.4v. So your voltage has to be stable. Those amps do 1200 at 11-14.4 volts. They're constant power amplifiers.
