lotus Posted May 19, 2012 Report Posted May 19, 2012 I built a 5.3 cu gross box (3/4 mdf) for my 2 12 xds with 2 braces and a baffle over the sub holes. There on the vfl 100.1 getting 1500watts but I wanna upgrade and keep the box. If I run 3000-4000 and get the xfls or hds will the box be able to handle it? 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH
ALPINE408 Posted May 19, 2012 Report Posted May 19, 2012 Glass does not add power handeling we have ran 20 to 40k in boxes with out any glass doing 160+ just need good braceing Have you ever had your woofers blown?
AI James Posted May 19, 2012 Report Posted May 19, 2012 oh boy, the glass inside the box is the new fad.
ALPINE408 Posted May 19, 2012 Report Posted May 19, 2012 Lol james shouldn't you be working? Have you ever had your woofers blown?
bass_stalker Posted May 19, 2012 Report Posted May 19, 2012 as long as you build the box properly and brace the box properly it should handle the power you throw at it JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Sheena Posted May 19, 2012 Report Posted May 19, 2012 That box is so huge for 2 12s. Depends what your build quality is, and what methods you use. In 4 cu ft boxes I use torx bit screws 1 1/2" long, tite bond II and silicon, with one dowel from top to bottom. In 3k watt applications you just run more supports if you aren't glassing, in addition to top and bottom, you do front to back, and side to side, and one in the port. (I haven't built for anything over 1500 watts. But that's just what I'd do if I couldn't fiberglass) 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
HatersGonnaHate Posted May 19, 2012 Report Posted May 19, 2012 Glassing the inside earns about as many cool points as liking your own posts. Just sayin'. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
AI James Posted May 19, 2012 Report Posted May 19, 2012 Lol james shouldn't you be working? im at an event for my daughter, i'll be at the shop in about an hour
lotus Posted May 19, 2012 Author Report Posted May 19, 2012 The subs have 4.4cu between them. Its at 36hz and sounds a lot better then the prefab box I had. The xfls and hds magnets are like 3x bigger then the xd. So I'd believe it would take up a lot more space. Its also a little taller and more than double the weight. I just hope the box can take them on 3k or 4k watts. My amps on the box... No where else to put it but I put rubber inbetween the box and amp. And its firing into the cab in my cobalt coupe. Hope the amp and box will be ok with the power increase 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH
getlocivic Posted May 19, 2012 Report Posted May 19, 2012 woofer displacement from the xd to hd is not as "huge" as you think it is lol box is fine for either but my god thats a high tune
