jg23 Posted May 20, 2012 Report Posted May 20, 2012 ahh the dreaded gm pcm. i heard that just keeping the headlights turn on solves the problem, but i have an old ass toyota so i cant tell you for sure. turn your headlights on and see what the voltage stays at when it usually drops to 12v or whatever. i said this before but you probably read over it this does work on pcm controlled alts. mine would rest like around 12.8 or lower and when the lights are on it would stay at 13.8. what i ended up doing though is just putting a non pcm alt to bypass it. i charge at 13.9-14.1 all the time, only thing is that the battery light is on 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
Sheena Posted May 20, 2012 Report Posted May 20, 2012 stuffs getting complicated way too fast.. start with the easy questions. is the alt dead? is the alt even in H/O mode? on my civic i can sit at 12.6 ALL DAY with the car running due to PCM. the simplist fix in the entire world is......... DRIVING LIGHTS! (not your head lights on, but the option before headlights) tada, alt sees the load and goes into H/O mode. voltage is now 14.X another thing is, the A/C switch, turning my A/C on flips my alt into H/O mode. dick around with your factory electronics to see which one flips yours into H/O mode. most likely the A/C will do it. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Junior Russell Posted May 20, 2012 Report Posted May 20, 2012 id still say try and external regulator instead of sending it to the pcm http://www.qualitypowerauto.com/catalog.php?item=148 http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
Amart88 Posted May 20, 2012 Author Report Posted May 20, 2012 OK, auto lights on voltage goes to 13-8-14.1 auto lights of 12.9 so there. That was the problem Thanks for the advice all of you i made another vid ill post in a bit My 2005 s10 blazer build. 4 zcon 18's walled.
Guest Posted May 20, 2012 Report Posted May 20, 2012 well that was easy, wasnt it lol. free fixes are the best fixes
Sheena Posted May 20, 2012 Report Posted May 20, 2012 well that was easy, wasnt it lol. free fixes are the best fixes true enough. just needed 15 people to post the same thing. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Amart88 Posted May 20, 2012 Author Report Posted May 20, 2012 well that was easy, wasnt it lol. free fixes are the best fixes well that was easy, wasnt it lol. free fixes are the best fixes true enough. just needed 15 people to post the same thing. Yes indeed, free is always good. No complaints here. Yeah it takes alot to get through this thick head lol My 2005 s10 blazer build. 4 zcon 18's walled.
Amart88 Posted May 20, 2012 Author Report Posted May 20, 2012 I'm kind of wanting 2 more btls now here the other one, not the best vi but yeah My 2005 s10 blazer build. 4 zcon 18's walled.
Kyblack76 Posted May 20, 2012 Report Posted May 20, 2012 there ya go man... glad it worked out for you.... and the "wanting more" is all part of the game... congrats bro... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Junior Russell Posted May 21, 2012 Report Posted May 21, 2012 now that youve figured out that your car needs a load for the alt to work like you want it to you have the option of doing an eld mod on your car... i know this is for a honda but hatersgonnahate has a tut on how to make one seen here: http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/ http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
