Shim Stuck After Recone HELP!
no problem dude, my subs are still holding up just fine using those materials, i ran the sa15s at a half ohm on an aq2200 they got moving pretty good no rips or any glue failuires.
Hopefully (crossing my fingers) if the guy gets his hands on another kit and I can re do these I would be running 1000w to each. Just in case anyone missed it these are the old school 12" RF HX2's and I am using Sundown Audio Z.v2 soft parts (double spiders).
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Damn bro, that blows. :(
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
i wouldnt trust 5min epoxy on a sub. and i dont even use activator on CA glue. I just let it dry naturally. i have a belief that it forms a stronger bond that way.
when you clamped the spider down you could have pushed things one way or the way the clamps grab might cause them to pull. when you cut this recone out, set it somewhere so that you can look at how the former and the spiders line up. see if they are crooked.
for shims i use an old for sale sign, they can be bought at any hardware store, maybe even walmart. they are plastic, and are thicker than paper, very hard to rip. also use strips.
That is an excellent idea.
Okay so I should just get the CA no activator and is it necessary to really use rubber glue? Can I get away with CA for the whole recone?
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
you can use CA for the entire recone, but i use rubber on the cap, because if you need to take it off for any reason, you can with a razor blade, when you do the cap in CA, you could end up fucking up the cone.
how i do it
-ca on the spiders and surround
-rubber on the cap
edit: and i have had to take a cap off to check the coil alignment before on subs to find bubbled out piece of the former, instead of playing the guessing game.
how i do it
-rubber on the cap
Okay cool ca everywhere and rubber on the cap got it.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
my recones have always come with a bottle of CA and rubber glue. its sad that yours didnt.
I didn't buy mine from a company I bought the softparts in pieces from someone on here and put it together no biggie though I have some CA and a whole lot of rubber so I will just purchase a bottle of CA to make sure I have enough to get it done completely. I just want to honestly get it done and playing.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
wierd ive never had a problem, my sa15s look fine. I reconed a level 4 15 with the same materials and the sub worked til i put a knife thru the sorround to build it down to a 12. That 12 has been in my buddies car for 2 years now with no issues.
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
