Go-N-Def Posted May 25, 2012 Report Posted May 25, 2012 so i finally hooked up my dc xl nobody said that shit was so vicious. it's wired at .5 omh because the the olny way to get good power going to it with the only amp i got. anyhow i think im tuned to around 35hz. my prob is my subs only sound good on low song id like it to be universal , so im thinking tuning to 38 would that do the trick? looking to play different types of music or everything not just low songs. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
That1Kid Posted May 25, 2012 Report Posted May 25, 2012 What amp? You probably aren't seeing much more power at. 5 than you would at 1. And why do you "think" you're tuned to 35? Maybe the tuning is lower than you think. -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
Sketchup Posted May 25, 2012 Report Posted May 25, 2012 haha yeah I'm sure it would, my friends 18 was at 33hz, he never even touched a lot of the highs. Another friend rocking his 2 12s had them at 36hz the subs were on about 600w, they did fine on the higher stuff but the power and strength would you say wasnt really there on some of those low low songs. Setup Ride: Toyota Corolla Headunit: Alpine CDE-123 Subwoofers: Fi Q 18 Amplifiers: Memphis 16 Pri-1000 Speakers Front: JL Audio TR650-CSI Comp's Speakers Back: JL Audio TR650-CSI Coax's
Go-N-Def Posted May 25, 2012 Author Report Posted May 25, 2012 What amp? You probably aren't seeing much more power at. 5 than you would at 1. And why do you "think" you're tuned to 35? Maybe the tuning is lower than you think. crossfire vr1000d, i reall dont know what it does @ 1 ohm. tuning i punch the numbers in on torres. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Kyblack76 Posted May 25, 2012 Report Posted May 25, 2012 Id find out fir sure where your at,... Tune wise... Where is your low pass set at? .... Just curious SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Hugh G. Rection Posted May 25, 2012 Report Posted May 25, 2012 just depends. some boxes have a wider pass band than others. mine plays over 149 on tl from 24hz all the way to 55hz. Owner of BigAss Ports
bkolfo4 Posted May 25, 2012 Report Posted May 25, 2012 What is the high pass filter set at? Sometimes it is not just the tuning, but also the size of the box. The sub more than likely will play up to 100+ Hz in the box you have now, but the design has a peak above tuning that is overpowering frequencies above the peak. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Go-N-Def Posted May 25, 2012 Author Report Posted May 25, 2012 dont know but i'll check them out Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Go-N-Def Posted May 26, 2012 Author Report Posted May 26, 2012 sub/s was 20hz and sub fq was 50hz Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
