neonhomer Posted June 21, 2015 Report Share Posted June 21, 2015 Any thoughts on making a horizontal or vertical bar version? I love the concept of the VM-1 (going to be ordering one hopefully on Wednesday), but the size makes it a bit difficult to find a place in my Passat to mount it. I was thinking a horizontal bar graph style would be a compact design for tight spaces... Though I just had a thought! Mount it to the visor! Then you can flip it down when you need to see it, and flip it out of the way when you don't! 1 Quote Link to comment Share on other sites More sharing options...
jbeez Posted July 1, 2015 Report Share Posted July 1, 2015 Thanks so much Steve, I got the wire today, and the DD1 I ordered so I cant stop lugging that huge oscope out just for gain setting lol Quote Link to comment Share on other sites More sharing options...
Ronco160 Posted August 18, 2015 Report Share Posted August 18, 2015 Any working coupon code? I tried smdvm1 didnt work Quote Headunit in mustang deh-p7000bt (Max undistorted volume 59) Headunit in gti deh-6000ub (max undistored volume 59) Amp=saz-1000d (Gain set with dd-1) Subwoofer= psi platform 3 18" (dual 1ohm) Link to comment Share on other sites More sharing options...
ShowtimeElectronics Posted August 18, 2015 Report Share Posted August 18, 2015 You can use SMD10 to get 10% off at Showtime: http://showtimeelectronics.com/shop/steve-meade-smd-vm-1-vm1-car-audio-10-1v-15-8v-volt-meter/ Quote Showtime Electronics Authorized Dealer For Many Popular Brands Including XS Power, Kicker, McLaren, Beyma, Ampere Audio, DC Audio and more! Site: www.showtimeelectronics.com eBay: www.stestore.net Amazon: www.amazon.com/shops/showtimeelectronics Email Us : [email protected] Link to comment Share on other sites More sharing options...
Keagan-Z06 Posted September 30, 2015 Report Share Posted September 30, 2015 Where is the best place to wire the VM-1, are most of you guys hooking it up directly to the power, ground, remote of your amp? Should I want the actual read out of my battery/alternator or the output from the amp? I will not be using the cig adapter. Thanks, Keagan Quote HU: Pioneer 4100 NEXSubs: 2 Rockford Fosgate R2SD4-10"Amp: Rockford Fosgate P500-1bd wired @ 1ohmFront: Polk Audio Components DB6501Amp: Pioneer GM A5602 wired @ 4 ohmRear: Polk Audio Coaxials db651s(2) OM-1s, (1) VM-1 Link to comment Share on other sites More sharing options...
tboorn Posted September 30, 2015 Report Share Posted September 30, 2015 Where is the best place to wire the VM-1, are most of you guys hooking it up directly to the power, ground, remote of your amp? Should I want the actual read out of my battery/alternator or the output from the amp? I will not be using the cig adapter. Thanks, Keagan if you want to monitor your amplifier, than the best place you can wire it is directly to the +/- terminals, and the remote turn on. Quote Fidelity Built to Last Team Sound Asleep 24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/ 2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3 2 DD M3b Maxwell 2.7V 3000F Supercapacitors Pioneer DEH-80prs Focal P165 V30 components Rockford Fosgate T-400.4 Link to comment Share on other sites More sharing options...
Keagan-Z06 Posted September 30, 2015 Report Share Posted September 30, 2015 Where is the best place to wire the VM-1, are most of you guys hooking it up directly to the power, ground, remote of your amp? Should I want the actual read out of my battery/alternator or the output from the amp? I will not be using the cig adapter. Thanks, Keagan if you want to monitor your amplifier, than the best place you can wire it is directly to the +/- terminals, and the remote turn on. Sorry, I was to say monitor the alternator voltage and not the voltage at the amplifier. Or it doesn't matter? Would it be that much of a difference whether I do it at the amp vs the Alternator? Quote HU: Pioneer 4100 NEXSubs: 2 Rockford Fosgate R2SD4-10"Amp: Rockford Fosgate P500-1bd wired @ 1ohmFront: Polk Audio Components DB6501Amp: Pioneer GM A5602 wired @ 4 ohmRear: Polk Audio Coaxials db651s(2) OM-1s, (1) VM-1 Link to comment Share on other sites More sharing options...
neonhomer Posted September 30, 2015 Report Share Posted September 30, 2015 With car audio, you are better off knowing what kind of voltage your amp is seeing, than what the alt is putting out. It does no good to know your alt is putting out 14v, but your amp is probably getting 12.8v because you have a bad wire. This is where having dual voltage gauges helps. You can read the output of your alt, and the input to the amps. Can help to spot wiring troubles. With multi-amp systems, you can monitor at the closest distribution block that serves all amps. 1 Quote Link to comment Share on other sites More sharing options...
Keagan-Z06 Posted September 30, 2015 Report Share Posted September 30, 2015 With car audio, you are better off knowing what kind of voltage your amp is seeing, than what the alt is putting out. It does no good to know your alt is putting out 14v, but your amp is probably getting 12.8v because you have a bad wire. This is where having dual voltage gauges helps. You can read the output of your alt, and the input to the amps. Can help to spot wiring troubles. With multi-amp systems, you can monitor at the closest distribution block that serves all amps. That about pretty much clears it up for me! Thanks man! Quote HU: Pioneer 4100 NEXSubs: 2 Rockford Fosgate R2SD4-10"Amp: Rockford Fosgate P500-1bd wired @ 1ohmFront: Polk Audio Components DB6501Amp: Pioneer GM A5602 wired @ 4 ohmRear: Polk Audio Coaxials db651s(2) OM-1s, (1) VM-1 Link to comment Share on other sites More sharing options...
Lakeshow94 Posted October 8, 2015 Report Share Posted October 8, 2015 Anyone know when wc car audio will be back in stock? Quote 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5 Link to comment Share on other sites More sharing options...
