How do you set one up? I mean, I'm trying to do a fully active crossover setup with the tweeters running off a separate amp. Is there any way of keeping each set of speakers from "overlapping" each other? Basically limiting them only to certain frequencies. Like 20-80hz for subs, 80-200hz for midbass, 200-~2000hz for mids, and then ~2000hz or up for tweets? I've always been curious about this.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
Simple ... get you a external active crossover, or a bad ass headunit with High pass, band pass, low pass, and subwoofer pass selection capabilities ...
and BTW, who told you that "overlapping" frequiencies was a bad thing ??
No one told me that. I just thought it was. My current build used to be really peaky around 100hz until I put an 80hz high pass on my components and an 80hz low pass on my subs, so that's one reason. I can admit that I'm probably mistaken though.
Lane AKA HeroKight
R.I.P. Molliboo
You hear that????
Buy a good head unit that has a built in active crossover. It can be difficult to find one that will support a 3 way active front stage though, so I suggest running your midrange and midbass together and use your amp's high pass/low pass filters to seperate them. The only pain with that is that most 2 or 4 channel amps have shit crossovers on them, that won't allow you to set the LPF higher than 150-250Hz.
Here's how I have mine set up:
Head unit: Sub: LPF - 63Hz
Mids: HPF - 63Hz - LPF - 3.15kHz (midbass and midrange both receive signal from this output)
Highs: HPF - 3.15kHz
Amps: Sub: No LPF, SSF Off (set to 7Hz below box tuning, or to about 25Hz for most people)
Midbass: No HPF, LPF - 315Hz
Midrange: HPF - 315Hz, No LPF
Tweeter: No filters
Edited by Autruche
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
some good info,.... but, i myself like to "over lap" where i can,... i also run different on my slopes,... 12db or 24db.... i mix and match my slopes, to, well,... have a slope, on some of the freq's i want to,..... and not just a direct cut or drop off.....and prefer band passing anywhere you can... i band pass every one of my speakers...
but, im usually doing things all flip flop...only worried about my ear though...lol
Edited by KyLar96
  • 10 years later...
