im thinking about switching from conventional tofull synthetic because of engine life n what not. is it worth it or should i just run conventional. i got my 91 blazer. im doing a tuneup so im trying to find out within the hr. thank you
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
How many miles on it? I just started runing synthetic in my car. I find it runs smoother myself. But its has 100k km on it. It's supposed to be better in the long run so why not. You will have people tell you not to because of a bunch of things they "heard" but alot of that was years ago when synthtic was starting out.
I used Mobil 1 as I heard good things about it. Amsoil is supposed to be the best but Mobil 1 is second to that. Another note. You pay more for synthetics but it will last alot longer before an oil change is needed.
Edited by Amart88
just run a high mileage oil. problem with synthetic is once you run it you cant go back to conventional, and usually with synthetic your oil changes are stretched out more
its got a 1xx,000 on her. im nnot worried about going back. the extra buck or few bucks a quart doesnt bother me. so possibly runs smoother . allright. thatd be nice since my babys running a lil rough right now. imma give it a go.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
That is a statement that has 2 answers. Yes you can and no you can't so....
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
i'm just going by what happened to my dad, though this was a few years back, when we used syenthetic in his elcamino. it ran fine until we got in a pinch and had to use conventional again, after we swapped back we had leaks from the rear main seal and the oil pan gasket.
I use vavloline full synthetic. Seen better mph right off rip plus as long as its changed every 3000 miles, got a 300000 mile warranty on the engine :)
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
from my experience never had a problem switching back and forth between conventional and synthetic..... my car has 124k on it and have switched back and forth 2 times due to money issues LOL..... never had a problem with leaking BUT did notice when you switch from conv. to synth BACK to conv. oil it gets black quick.....like in 2000 miles..... my car usually can go 3000 and just barely be dark on conventional..... synthetic i can go like 6k til it starts turning dark.
synthetic is the way to go..... way better IMHO
EDIT: last oil change was with royal purple 10w30 synthetic and will never buy it again..... lasted 3k and BLACK as all hell not worth the money at all.....$10/ quart @ 5 quarts + $25 for RP filter= lotza money for "great" oil and a not so happy customer.....
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
It doesn't matter if the oils black. Royal purple starts off dark purple. Easier to turn black. As long as the oil doesn't break down and get sludgey
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
