Yep, this is not uncommon with Optimas now-a-days. The red top in my Mustang typically rests at between 11.8 and 11.9 VDC. I really can't comment why this is because I'd be guessing, but this is something that I run into often. Maybe one of the battery gurus here can chime in - Nate? Scottie?
My red top sits around same. With other people seeing the same low voltages on Optima's I am going to assume it has to do with the battery design.
Charge them with an AGM compatible charger and let them sit overnight. If the voltage falls back in the 11's, they're toast. Could be from a combination of high engine heat and high charge voltage (relative to battery temp). Heat and excessive charge voltage are the #1 killer of AGM type batteries.
XS POWER Batteries, Chargers & Accessories
888-4XS-POWER
Mine float at 12.91 or greater. Thank you tottie johnson for such an awesome intellicharger
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ok I'll get a AGM charger. Got 1 more ? Can I charge them with my amps still connected or do I need to disconnect them ?
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
