im going to be having my grad party on the 23rd, and im expecting to acquire a good amount of money.
i already started college and have everything i need, so all proceeds go to what i want ^_^
that means new gear!! including at least one set of RE Audio XXX 6.5's
but that means i need an amp that puts out 600watts / 300wrms.
i'd still like to keep it on a reasonably budget, so that pretty much cuts out JL Audio.
ideas?
e/: i was looking at a 720w peak kenwood amp, but i've heard they run kind of hot?
Edited by Robby Holmes
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
The XXX's don't need that much power. I would look into a nice 150 watt per channel amp.
This one from Arc should fit the bill just nicely:
http://www.arcaudio....ries/ks3002.asp
yeah but im trying to have the amp match the speaker for frontstage
and they recommend 150rms each
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Screw matching power ratings on speakers as they'll take more power like subs can if your smart about it and don't blow them.
More power is better in front stage as it means less distortion and a cleaner sounding front stage to build you sub stage on.
150w is a bare minimum for fronts but don't be afraid to get up into 300w per channel, it doesn't mean you'll use all that power it just means you'll have the power needed to play the level you want to listen to cleanly and without distortion.
EDIT: Look into the ZED Audio , Zuki custom , RF T1000.4
http://www.zedaudiocorp.com/index.php/products/leviathan-iii/item/leviathan-iii.html
http://www.zukiaudio.net/Custom.html Do NOT let the ratings fool you, 5 zuki watts are close to 175 watts
http://www.sonicelectronix.com/item_34753_Rockford-Fosgate-T1000-4AD.html
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
alright, im new to front stage and have never used crossovers, or even external amps for aftermarket speakers.
could i get a quick like... 101 on front stage? haha
edit: also, i need to know how many batteries i need for ~3,000 rms
stock 140amp alternator, awaiting my big 3 upgrade
i was looking at keeping my interstate battery as my main, and 2 yellowtops for my trunk
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
your speakers are 2ohm
as i posted before and both are very modest pricing
180x2 @2
http://www.sonicelec...io-JX360-2.html
150x2 @2
http://www.sonicelec...e-PBR300X2.html
nah i understand that, i just want to see what all my options are and i do appreciate your input and help ^_^
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
im getting this one but im running more than one set of speakers.
http://www.sonicelectronix.com/item_38338_Precision-Power-P900.4.html
Edited by pimpnFosgates
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
