I have a "Plum Crazy" Purple Linear Power 2.2HV that would get you close ... High Voltage Class A/B amp ...
I'm asking 600.00 dollars for it ...
Bridge a powerful 2-channel amp.
The DD S2b is rated at 1600 bridged @ 4 ohms and 2700 @ 2 ohms.
http://www.ddaudio.c...series/s2b.aspx
Anything high end at around 400w x 2 should bridge to around 1500 watts.
It's going to be very costly on your electrical though, as most of these types of amps are class AB.
lol what? i've never heard of this theory before. since when should "high end" amps output twice their rated power when bridged?
will they require higher amperage as opposed to a class d running at 1600 rms?
Class A/Bs are high voltage amps ... Class D amps are High current amps ... They will pull load ampreage about the same ... depending on the amp quality ...
how exactly does an 800 watt amp become a 1500 watt amp when you bridge it?
OP-the gain to cost benefit is going to be ridiculous here. You will see a minimal drop in distortion (most likely not even audible) and a minor increase in efficiency. Now ever, if you can't support 1500 watts @1ohm the efficiency increase going to 1500 watts @4ohms won't be enough to help.
Edit: Ninja'd by Kranny :(
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Most Class A/B amps back in the day rated their amps at about 20 to 40 percent of their capabilities at 50 htz to where everyone now rates power at 1000 htz ... who here has ever seen a bass amp play tones at 1000 htz on a daily setup ...
You would be suprised at what a class A/B amp can do for subs (Musically) ... I'm not talking about hair tricks and burps ...
Edited by Cablguy184
I can add to the Class A/B Doing for subs. For the longest time I had my 2 10's on a Alpine MRV-F250, I have to say they sounded the best off that compared to either MB Quart amp I have in my car now. They sounded AMAZING! it was only outputing 70 watts in total, and how hard it hit is damn easily comparable to the same subs on an MB Quart FX1.600 running 300 watts in total.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
why does it say 120 db over my picture?
I'm assuming reputation points ...
I don't think the difference you would notice (doubt it would be any) would be worth the much higher cost of the amp you'd need. People talk about the difference in damping factor between 1ohm and higher loads, but the difference to your ear will honestly be little to none.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
