If I disconnect two(front) of the four rca's, will the amp draw less current because it doesn't have to amplify a signal on from those two? Like for burps only. (Sub on the rear channels). Trying to fuse down as much as possible.
SMD Super Seller
My Feedback Thread
Personally, I would use 2 separate power supplies (amps) ... you might take a chance of burning out 2 of those channels without haveing RCAs not connected to a running amplifier ...
If you want to go low wattage ... Use a Class A/B sub amp ...
Edited by Cablguy184
I wouldn't recommend running a amplifier without any source RCAs hooked to it ...
Just saying ...
you could hook up DMM to the outputs of rcas you disconnected to see if you get any signal out
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
