question for the good box builders here
is it possible to tune a box to 2 frequencies if you have a double reflex bandpass or what ever the hell its called. because it does have 2 ports.
i dont think its possible to tune it to two separate frequencies without using swappable ports. however, a lot of enclosures may have two or more seperate peaks...like one peak at 40hz and the other peak at 60hz for example. and a perfect enclosure would have the same "loudness" from whatever the lowest frequency desired to the highest frequency desired regardless of volume, aka a flat response curve.
someone plz feel free to correct me if im wrong...cause im still learning too..
Edited by amatt85
i likes me some audio stuff...
i dontknow what its called but i drew up a quick sketch on paint.net
so have that and have one port at like amatt said at 40Hz and one at 60Hz
but i dont see how this will work now that i really get thinking about it
kuz while one is hitting the 40s nicely the other would just be there kinda messin with the good one and then the opposite way for when hitting likes 60s
please help me here kuz i have no idea what the hell im talking about
hahaha well i learned some thing new today, so is it possible to have it tuned to 2 different frequencies? or is that just really pointless, becaused what amatt said if you got a good box it should have more then one peak or what ever?
I may be wrong but I would say no to that with this design. You may be able to tune the front and rear chambers seperate but you will more than likely destroy your sub after a short period of time.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
i dont fully understand at all, lol but thanks for trying to tell me, i wasnt planning on making any thing like that so it doesnt matter. i was just wondering if that would work.
with a dual tuned bandpass, it usually peaks in the average point between the 2 freqs
say if you tuned it to 30hz and 60hz, you will see gain at 45hz.... Depending how well you dsign the box, it will be really peaky 1 tone box, or a gentle roll from 30-60hz with a slight peak in the middle
(if seen on a graph)
