MTTornquist's Corolla SQ Build *now with Linear Power 11/26
It shows you took your time assembling the box! Looking good indeed.
I'm just a bit confused: are you installing the Audison amp instead of the Skar?
I'm not a fan of installing amps on a sub box. I'm always seeing it as a vibrating - solder ripping machine. But then again, the whole car is vibrating, so don't know if it really makes any difference nor if it really could harm an amp.
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
Like it man. Looking great. Cant wait to see it finished
Thanks man its almost there!!
on the other side: it saves a lot of room offcourse :-)
Yeah I've head that it isn't always the best idea but for the amount of time i will be running full tilt i don't foresee any problems.
And its only about 200W anyhow :good:
Update time!!
Been a couple days since I got anything done, well its painted now.
Still gotta dry but when it is it'll be playing!!!
who are you guys kidding, no way I would paint anywhere near that beautiful floor! :P
after it dries its ready to make some noise!
Cant wait to rebuild mine for my new car
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
meanwhile the paint is now dry:
And I got my ground post put in, there was a hole from the factory that was perfect for what I needed. Just had to sand the paint!
Sanded clean:
And the bolt on tight:
This ground should be much better than my original one. That was just a self taping screw into the floor of the trunk.
So everything is ready to be installed, I just need to find the time to put it in!
Everything should be up and running by this weekend! :good:
Check in soon, its almost there.
But wait..... there's more stuff in the mail too :ninja:
Here we goooo!! :D
Time for the install, I've waited for this for a long time!
Started by attaching the xovers to the sides of the box.
Some 3m industrial double stick tape got the job done:
On there:
Then the amp goes on:
Grounded it up:
Hooked up, tuned it with my dmm:
Had to stop taking pictures because I had to finish it up before school yesterday, But its done now!
Kindof. I need to design a beauty panel for the backside to clean it all up.
Pics:
The trunk isn't sealed off quite perfectly yet either.
But its playing finally!
And it sounds damn good, I'm impressed :good:
Thanks for looking!
Where is the vid of it playing?
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
