Fi SSD's with the High QTS package, slightly above your budget, but worth it!
Why do you want D4 btw? Do you want a final load of 1 ohm for two of them? You can get a final load of 1 ohm by wiring the Dual 1Ohm voice coils of each sub in series, than the two subs wired in parallel to the amp.
I want D4 because i plan to run 24 in all and 8 on one amp so i need D4s
Get the D1's, wire all four voice coils of Two of them in Series, and then wire the 4 sets of two in parallel for a final ohm of 1 Ohm per amp.
Edited by BobbyG2
*New vehicle and system coming soon.*
RE is meh. not the same RE if youre budgeting 200 per sub you can look into SSDs level 3s SA-10s or skar vvx 10s. those will be the most common answers
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I hop this helps:
Going by his budget and application, I think the SSD's with the High QTS Option will be his best bet, in a sealed enclosure. If it was ported, I'd think that they'd be on a much more level playing field though!
Edited by BobbyG2
Do this, but with 4 sets of 2:
hes gonna run 24 of them i hgihgly doubt its gonna be sealed.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 4809 Guests (See full list)
