most amp power for VVX
I'm running two vvx 12 on brz 1700 at .5ohm. Voltage drop to 13.8 I guess I'm getting 1900w or so. That would be 800w to each. Just make sure you're sending clean power to them.
you are smart enough to set up an electrical system that will support a 1700 watt amp at .5 ohm but cant divide 1900 by 2 :lol: 1900/2= 950
but op i have mine on same amp and they take the power no problem
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
how are you running 2 dvc @.5 ohm? dual4 will give you 1ohm and dual 2 will give you 2ohm
Two dual two ohm subs can wire down to 2 ohms or .5 ohms.
your right my bad, so with the brz 1700 wired to .5 ohm you are only getting 1900? I think you would get more since its 1700@ 1ohm?
Im not sure if its just me so you went from an amp that does 5000w@1ohm to 2400w@1ohm and you are running this on .5ohm?
yes...and for those who are familiar with DD, know their amp ratings are a joke. The m3 does close to 4k
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
didnt the Powerbass xta 5k run more wattage than the DD m3? most bassheads will go higher instead of going lower unless something happened to the Powerbass xta 5k and you replaced it with the DD m3, not bashing just trying to understand
have you guys ever heard of impedance rise?
you could have a 5k amp wired to 1 ohm rising to 4 ohm and only getting maybe 2000 watts out of it.
Edited by aleroking
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
I had my 2 15's on my Colossus amp rated at 1,600 x 2 @ 2 for about 6 months no probs at all now the same amp is running at 1 ohm on all 4 15's
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
  • Who's Online   1 Member, 0 Anonymous, 1568 Guests (See full list)
