That's all you can wire it too.
And either the guy wired 1 sub up to 2 ohm, Or wired them up, and his meter just sucks. My meter is off .7, and can sometimes fool you. All depends on the meter.
With Dual 1s, You can either Wire to 1 ohm, each amp to .5 Ohm. ( Not recomended unless you have the electrical and know what your doing PROPERLY.)
Or Wire to 4 ohm, Each amp See's 2 ohm.
Edited by Katt
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Yes there dual 1 ohm subs. I need a final load of 2 ohm to the amp. So 2 dual 1ohm subs to a 2 ohm load on one amp. The amps are strapped so they need a 2ohm load
Dude, you CAN"T wire those subs to present a 2 ohm final load to the amp. It's either .25, 1, or 4....that's it.
*Edit- I was sure late to the party...I was meaning to respond, but didn't in time apparently
Edited by CleanSierra
Send them back and get the correct product.
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
